Going for a Ride
If your device was packaged with an ANT‍+® sensor, they are already paired and can be activated during initial setup.
  1. Hold Power symbol to turn on the device.
  2. Go outside, and wait while the device locates satellites.
    The satellite bars turn green when the device is ready.
  3. From the home screen, select Bicyclist symbol.
  4. Select Pause play symbol to start the timer.
    Timer data
    NOTE: History is recorded only while the timer is running.
  5. Swipe left or right to view additional data screens.
    You can swipe down from the top of the data screens to view the connections screen.
  6. If necessary, tap the screen to view the timer overlay.
  7. Select Pause play symbol to stop the timer.
    TIP: Before you save this ride and share it on your Garmin Connect™ account, you can change the ride type. Accurate ride type data is important for creating bike friendly courses.
  8. Select Save Ride.
  9. Select Checkmark.
Copyright © Garmin. All rights reserved.GUID-13DDC698-D64B-4D27-B790-38A7EAE15395 v3
