Using the Backlight
You can tap the touchscreen to turn on the backlight.
NOTE: You can adjust the backlight timeout (Display Settings).
  1. From the home screen or a data screen, swipe down from the top of the screen.
  2. Select Brightness.
  3. Select an option:
    • To manually adjust the brightness, use the arrows.
    • To allow the device to automatically adjust the brightness based on the ambient light, select Auto Brightness.
Copyright © Garmin. All rights reserved.GUID-13DDC698-D64B-4D27-B790-38A7EAE15395 v3
