Navigating Back to Start At any point during your ride, you can return to the starting point. Go for a ride (Going for a Ride). During your ride, select anywhere on the screen to view the timer overlay. Select > Navigation > Back to Start. Select Along Same Route or Most Direct Route. Select Ride. The device navigates you back to the starting point of your ride. Parent Topic: Locations
Navigating Back to Start At any point during your ride, you can return to the starting point. Go for a ride (Going for a Ride). During your ride, select anywhere on the screen to view the timer overlay. Select > Navigation > Back to Start. Select Along Same Route or Most Direct Route. Select Ride. The device navigates you back to the starting point of your ride. Parent Topic: LocationsHomeNavigationLocationsNavigating Back to Start
