Starting a GroupTrack Session
Before you can start a GroupTrack session, you must have a smartphone with the Garmin Connect™ Mobile app paired to your device (Pairing Your Smartphone).
During a ride, you can see the riders in your GroupTrack session on the map.
  1. On the Edge® device, select Menu symbol > Settings > GroupTrack to enable viewing connections on the map screen.
  2. In the Garmin Connect Mobile app, from the settings menu, select LiveTrack > GroupTrack.
  3. Select Visible to > All Connections.
    NOTE: If you have more than one compatible device, you must select a device for the GroupTrack session.
  4. Select Start LiveTrack.
  5. On the Edge device, select Pause play symbol, and go for a ride.
  6. Scroll to the map to view your connections.
    GroupTrack data
    You can tap an icon on the map to view location and heading information for other riders in the GroupTrack session.
  7. Scroll to the GroupTrack list.
    You can select a rider from the list, and that rider appears centered on the map.
Copyright © Garmin. All rights reserved.GUID-13DDC698-D64B-4D27-B790-38A7EAE15395 v3
