Setting Up Extended Display Mode
You can use your Edge® device as an extended display to view data screens from a compatible Garmin® multisport watch. For example, you can pair a compatible Forerunner® device to display its data screens on your Edge device during a triathlon.
  1. From your Edge device, select Menu symbol > Settings > Extended Display Mode > Connect Watch.
  2. From your compatible Garmin watch, select Settings > Sensors & Accessories > Add New > Extended Display.
  3. Follow the on-screen instructions on your Edge device and Garmin watch to complete the pairing process.
    The data screens from your paired watch appear on the Edge device when the devices are paired.
    NOTE: Normal Edge device functions are disabled while using Extended Display mode.
After pairing your compatible Garmin watch with your Edge device, they connect automatically the next time you use Extended Display mode.
Copyright © Garmin. All rights reserved.GUID-13DDC698-D64B-4D27-B790-38A7EAE15395 v3
