Using the Backlight
You can select any key to turn on the backlight.
NOTE:
You can adjust the backlight timeout (Display Settings).
- Select .
Select an option:
To allow the device to automatically adjust the brightness based on the ambient light, enable Auto Brightness.
To manually adjust the brightness, disable Auto Brightness, select Brightness, and select
or
Parent Topic: Display Settings
