Segment Options
Select .
- Turn Guidance
Enables or disables turn prompts.
- Auto Select Effort
Enables or disables automatic goal adjustment based on your current performance.
- Search
Allows you to search for saved segments by name.
- Enable/Disable
Enables or disables the segments currently loaded on the device.
- Default Leader Priority
Allows you to select the order for goal targets while racing a segment.
- Delete
Allows you to delete all or multiple saved segments from the device.
Parent Topic: Segments
