Using Electronic Shifters
Before you can use compatible electronic shifters, such as Shimano® Di2™ shifters, you must pair them with your device (Pairing Your Wireless Sensors). You can customize the optional data fields (Adding a Data Screen). The Edge® 530 device displays current adjustment values when the sensor is in adjustment mode.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
