Map Themes
You can change the map theme to adjust the appearance of the map for your ride type.
Select , select a profile, and select .
- Classic
Uses the classic Edge® map color scheme, with no additional theme applied.
- High Contrast
Sets the map to display data with higher contrast, for better visibility in challenging environments.
- Mountain Biking
Sets the map to optimize trail data in mountain biking mode.
Parent Topic: Map Settings
