Enabling Segments You can choose which segments currently loaded on the device are enabled. Select Menu > Training > Segments > Segment Options > Enable/Disable > Edit Multiple. Select the segments to enable. Parent Topic: Segments
Enabling Segments You can choose which segments currently loaded on the device are enabled. Select Menu > Training > Segments > Segment Options > Enable/Disable > Edit Multiple. Select the segments to enable. Parent Topic: SegmentsHomeTrainingSegmentsEnabling Segments
