Going for a Ride
If your device was packaged with a wireless sensor, they are already paired and can be activated during initial setup.
  1. Hold Power on off symbol to turn on the device.
  2. Go outside, and wait while the device locates satellites.
    The satellite bars turn green when the device is ready.
  3. From the home screen, select Enter menu symbol.
  4. Select an activity profile.
  5. Select Start stop symbol to start the activity timer.
    Activity timer with bike data
    NOTE: History is recorded only while the activity timer is running.
  6. Select Up arrow symbol or Down arrow symbol for additional data screens.
  7. If necessary, select Enter menu symbol to view menu options such as alerts and data fields.
  8. Select Start stop symbol to stop the activity timer.
    TIP: Before you save this ride and share it on your Garmin Connect™ account, you can change the ride type. Accurate ride type data is important for creating bike friendly courses.
  9. Select Save Ride.
Copyright © Garmin. All rights reserved.GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v6
