NOTE:If you do not have this mount, you can skip this task.
Select a secure location to mount the
Edge® device where it does not interfere with the safe operation of your bike.
Use the hex key to remove the screw from the handlebar connector .
Place the rubber pad around the handlebar:
If the handlebar diameter is 25.4 mm or 26 mm, use the thicker pad.
If the handlebar diameter is 31.8 mm, use the thinner pad.
If the handlebar diameter is 35 mm, do not use a rubber pad.
Place the handlebar connector around the rubber pad.
Replace and tighten the screw.
NOTE:Garmin® recommends tightening the screw so the mount is secure, with a maximum torque specification of 7 lbf-in. (0.8 N-m). You should check the tightness of the screw periodically.
Align the tabs on the back of the
Edge device with the bike mount notches .
Press down slightly and turn the
Edge device clockwise until it locks into place.
