Setting Recurring Alerts
A recurring alert notifies you each time the device records a specified value or interval. For example, you can set the device to alert you every 30 minutes.
  1. Select Menu > Settings > Activity Profiles.
  2. Select a profile.
  3. Select Alerts.
  4. Select an alert type.
  5. Turn on the alert.
  6. Enter a value.
  7. Select Checkmark symbol.
Each time you reach the alert value, a message appears. The device also beeps if audible tones are turned on (Turning the Device Tones On and Off).
Copyright © Garmin. All rights reserved.GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v6
