Pedal-Based Power
Rally™ measures pedal-based power.
Rally measures the force you apply a few hundred times every second. Rally also measures your cadence or rotational pedaling speed. By measuring the force, the direction of force, the rotation of the crank arm, and time, Rally can determine power (watts). Because Rally independently measures left and right leg power, it reports your left-right power balance.
NOTE: The single-sensing Rally system does not provide left-right power balance.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
