Customizing the Widget Loop
You can change the order of widgets in the widget loop, remove widgets, and add new widgets.
- Select .
- Select a widget to add or remove it from the widget loop.
- Select Reorder to change the location of a widget in the widget loop.
Parent Topic: System Settings
