Setting Your Heart Rate Zones
The device uses your user profile information from the initial setup to determine your heart rate zones. You can manually adjust the heart rate zones according to your fitness goals (Fitness Goals). For the most accurate calorie data during your activity, you should set your maximum heart rate, resting heart rate, and heart rate zones.
  1. Select Menu > My Stats > Training Zones > Heart Rate Zones.
  2. Enter your maximum, lactate threshold, and resting heart rate values.
    You can use the auto detect feature to automatically detect your heart rate during an activity. The zone values update automatically, but you can also edit each value manually.
  3. Select Based On:.
  4. Select an option:
    • Select BPM to view and edit the zones in beats per minute.
    • Select % Max. to view and edit the zones as a percentage of your maximum heart rate.
    • Select % HRR to view and edit the zones as a percentage of your heart rate reserve (maximum heart rate minus resting heart rate).
    • Select %LTHR to view and edit the zones as a percentage of your lactate threshold heart rate.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
