Applied Ballistics Options
From the watch face, press GPS, select Applied Ballistics, and press GPS.
Quick Edit
Allows you to quickly edit the range, direction of fire, and wind information (Quickly Editing Shooting Conditions).
Range Card
Allows you to view data for various ranges based on user input parameters. You can change fields (Customizing the Range Card Fields), edit the range increment (Editing the Range Increment), and set the base range (Setting the Base Range).
Target Card
Allows you to view range, elevation, and windage for ten targets based on user input parameters.
Environment
Allows you to customize atmospheric conditions for your current environment. You can enter custom values, use the pressure and latitude values from the internal sensor in the device, or use the temperature value from a connected tempe™ sensor (Environment).
Target
Allows you to customize long-range shooting conditions for your current target. You can change the selected target and customize conditions for up to ten targets (Changing the Target).
Profile
Allows you to customize gun properties (Editing Gun Properties), bullet properties (Editing Bullet Properties), and output units of measure for your current profile. You can change the selected profile (Selecting a Different Profile) and add additional profiles (Adding a Profile).
Change Fields
Allows you to customize the data fields on the profile data screen (Customizing the Profile Data Screen).
Setup
Allows you to select the units of measure and enable the windage and elevation solution options.
April 2026
