Changing the Screen Settings
  1. Hold MENU.
  2. Select System > Backlight.
  3. Select Night Vision to reduce the backlight intensity for compatibility with night vision goggles (optional).
  4. Select an option:
    • Select During Activity.
    • Select General Use.
    • Select During Sleep.
  5. Select an option:
    • Select Brightness to set the brightness level of the screen.
      NOTE: If you enable night vision mode, you cannot adjust the brightness level.
    • Select Keys to turn on the screen for button presses.
    • Select Alerts to turn on the screen for alerts.
    • Select Gesture to turn on the screen by raising and turning your arm to look at your wrist.
    • Select Timeout to set the length of time before the screen turns off.
April 2026
