Viewing Tide Information
WARNING
Tide information is for information purposes only. It is your responsibility to heed all posted water-related guidance, to remain aware of your surroundings, and to use safe judgment in, on, and around the water at all times. Failure to heed this warning could result in serious personal injury or death.
When you pair your watch with a compatible phone, you can view information about a tide station, including the tide height and when the next high and low tides will occur.
  1. From the watch face, press GPS.
  2. Select Tides.
  3. Select an option:
    • Select a favorite or recently used tide station.
    • To use your current location when you are near a tide station, select Add > Current Location.
    • To select a saved location, select Add > Saved.
    • To enter coordinates for a location, select Add > Coordinates.
    A 24-hour tide chart appears for the current date with the current tide height 1 and information about the next tide 2.
    Tides chart with callouts
  4. Press DOWN to see tide information for upcoming days.
  5. Press GPS, and select Set as Favorite to set this location as your favorite tide station.
    Your favorite tide station appears at the top of the list in the app and in the glance.
April 2026
