Adding a Profile
You can add a .pro file that contains profile information by creating it using the Applied Ballistics Quantum™ app and transferring the file to the AB folder on the device. You can also create a profile using your Garmin® device.
  1. From the Applied Ballistics® app, press GPS.
  2. Select Profile > Profile > + Profile.
  3. Select an option:
    • To customize the bullet properties, select Bullet Properties (Editing Bullet Properties).
    • To customize the gun properties, select Gun Properties (Editing Gun Properties).
    • To change the units of measure for the output fields, select Output Units.
April 2026
