Customizing the Glance Loop
You can change the order of the glances in the loop, remove glances, and add new glances.
  1. Hold MENU.
  2. Select Appearance > Glances.
  3. Select an option:
    • Select a glance, and press UP or DOWN to change the location of the glance in the loop.
    • Select a glance, and select Delete to remove the glance from the loop.
    • Select Add, and select a glance to add it to the loop.
April 2026
