Resetting All Default Settings
Before you reset all default settings, you should sync the watch with the Garmin Connect™ app to upload your activity data.
You can reset all of the watch settings to the factory default values.
  1. Hold MENU.
  2. Select System > Reset.
  3. Select an option:
    • To reset all of the watch settings to the factory default values, including user profile data, but save activity history and downloaded apps and files, select Reset Default Settings.
    • To reset all of the watch settings to the factory default values and delete all user-entered information and activity history, select Delete Data and Reset Settings.
      NOTE: If you have set up a Garmin Pay™ wallet, this option deletes the wallet from your watch.
April 2026
