Calibrating the Drop Scale Factor
Garmin® recommends you calibrate the muzzle velocity prior to the drop scale factor.
Calibrating the drop scale factor provides a more accurate solution at or beyond the transonic range for your specific firearm.
  1. From the Applied Ballistics® app, press GPS.
  2. Select Profile > Gun Properties > Calibrate DSF.
  3. Select an option:
    • Select Range to edit the range.
    • Select True Drop to edit the drop distance.
  4. Select BACK.
April 2026
