Adding or Removing a Favorite Activity
The list of your favorite activities appears when you press GPS from the watch face, and it provides quick access to the activities you use most frequently. The first time you press GPS to start an activity, the watch prompts you to select your favorite activities. You can add or remove favorite activities at any time.
  1. Hold MENU.
  2. Select Activities & Apps.
    Your favorite activities appear at the top of the list.
  3. Select an option:
    • To add a favorite activity, select the activity, and select Set as Favorite.
    • To remove a favorite activity, select the activity, and select Remove from Favorites.
April 2026
