Quickly Editing Shooting Conditions
You can edit the range, direction of fire, and wind information.
  1. From the Applied Ballistics® app, press GPS.
  2. Select Quick Edit.
    TIP: You can press DOWN or UP to edit each value, and press GPS to move to the next field.
  3. Set the RNG value to the target distance.
  4. Set the DOF value to your actual direction of fire.
    TIP: To use the compass to set the direction of fire, you can press DOWN, then point the top of the device toward the target, and press GPS to select the current compass value.
  5. Set the W 1 value to the low wind speed.
  6. Set the W 2 value to the high wind speed.
  7. Set the DIR value to the direction the wind is coming from.
  8. Press BACK to save your settings.
April 2026
