Recording an Obstacle Racing Activity
When you participate in an obstacle course race, you can use the Obstacle Racing activity to record your time on each obstacle and your time running between obstacles.
  1. From the watch face, press GPS.
  2. Select Obstacle Racing.
  3. Press GPS to start the activity timer.
  4. Press SET to manually mark the beginning and end of each obstacle.
    NOTE: You can configure the Obstacle Tracking setting to save obstacle locations from your first loop of the course. On repeat loops of the course, the watch uses the saved locations to switch between obstacle and running intervals.
  5. After you complete your activity, press GPS, and select Save.
April 2026
