Playing Golf
Before you play a course for the first time, you must download it from the Garmin Connect™ app (Garmin Connect). Courses downloaded from the Garmin Connect app are updated automatically.
Before you play golf, you should charge the watch (Charging the Watch).
  1. From the watch face, press GPS.
  2. Select Golf.
  3. Go outside, and wait while the watch locates satellites.
  4. Select a course from the list of available courses.
  5. Select Check mark to keep score.
  6. Select a tee box.
    The hole information screen appears.
    Screenshot of the golf hole view with callouts
    1
    Distance to the front, middle, and back of the green
    2
    Par for the hole
    3
    Current hole number
    4
    Map of the green
    NOTE: Because pin locations change, the watch calculates the distance to the front, middle, and back of the green, but not the actual pin location.
  7. Select an option:
    • Press UP or DOWN to view the location and distance to a layup or to the front and back of a hazard.
    • Press GPS to open the golf menu (Golf Menu).
April 2026
