Getting Your VO2 Max. Estimate for Cycling
Before you can view your VO2 max. estimate, you must have a compatible heart rate monitor and a power meter. The power meter must be paired with your Forerunner® device (Pairing ANT+ Sensors). For the most accurate estimate, complete the user profile setup (Setting Up Your User Profile) and set your maximum heart rate (Setting Your Heart Rate Zones).
NOTE:
The estimate may seem inaccurate at first. The device requires a few rides to learn about your cycling performance.
- Ride at a steady, high intensity for at least 20 minutes outdoors.
- After your ride, select Save.
- Select .
Parent Topic: About VO2 Max. Estimates
