Setting a Recurring Alert
A recurring alert notifies you each time the device records a specified value or interval. For example, you can set the device to alert you every 30 minutes.
  1. Select Menu > Activity Settings > Alerts > Add New.
  2. Select an option:
    • Select Custom, select a message, and select an alert type.
    • Select Time, Distance, or Calories.
  3. Enter a value.
Each time you reach the alert value, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds).
Copyright © Garmin. All rights reserved.GUID-45C11350-FBF5-4264-8316-A857189282E1 v4
