Broadcasting Heart Rate Data to Garmin Devices
You can broadcast your heart rate data from your Forerunner® device and view it on paired Garmin® devices. For example, you can broadcast your heart rate data to an Edge® device while cycling, or to a VIRB® action camera.
NOTE: Broadcasting heart rate data decreases battery life.
  1. Select Down arrow symbol to view the heart rate widget.
  2. Hold Up arrow symbol.
  3. Select Broadcast Heart Rate.
    The Forerunner device starts broadcasting your heart rate data, and Heart rate broadcast symbol appears.
    NOTE: You can view only the heart rate page while broadcasting heart rate data.
  4. Pair your Forerunner device with your Garmin ANT‍+® compatible device.
    NOTE: The pairing instructions differ for each Garmin compatible device. See your owner's manual.
    TIP: To stop broadcasting your heart rate data, select any key, and select Yes.
Copyright © Garmin. All rights reserved.GUID-45C11350-FBF5-4264-8316-A857189282E1 v4
