Activity Settings
These settings allow you to customize each preloaded activity app based on your needs. For example, you can customize data pages and enable alerts and training features. Not all settings are available for all activity types.
Select , select an activity profile, and select
- Alerts
Sets the training or navigation alerts for the activity.
- Auto Pause
Sets the device to stop recording data when you stop moving or when you drop below a specified speed (Using Auto Pause).
- Auto Scroll
Enables you to move through all of the activity data screens automatically while the timer is running (Using Auto Scroll).
- Countdown Start
Enables a countdown timer for pool swimming intervals.
- Data Screens
Enables you to customize data screens and add new data screens for the activity (Customizing the Data Screens).
- GPS
Sets the mode for the GPS antenna. Using GPS + GLONASS provides increased performance in challenging environments and faster position acquisition. Using the GPS + GLONASS option can reduce battery life more than using the GPS option only. Using the UltraTrac option records track points and sensor data less frequently (Using UltraTrac Mode).
- Laps
Sets the options for the Auto Lap® feature (Marking Laps by Distance) and the lap alert message (Customizing the Lap Alert Message).
- Metronome
Plays tones at a steady rhythm to help you improve your performance by training at a faster, slower, or more consistent cadence (Running with the Metronome).
- Pool Size
Sets the pool length for pool swimming.
- Power Save Timeout
Sets the power-save timeout setting for the activity (Power Save Timeout Settings).
- Repeat
Enables the repeat option for multisport activities. For example, you can use this option for activities that include multiple transitions, such as a swimrun.
- Segment Alerts
Enables prompts that alert you to approaching segments.
- Stroke Type
Enables stroke detection for pool swimming.
- Transitions
Enables transitions for multisport activities.
- Customizing the Data Screens
- Alerts
- Using Auto Pause
- Running with the Metronome
- Marking Laps by Distance
- Customizing the Lap Alert Message
- Using Auto Scroll
- Changing the GPS Setting
- Power Save Timeout Settings
