Creating a Custom Activity Profile
- Select Menu > Settings > Activity Profiles > Add New.
- Select a sport.
- Select an accent color.
Select a profile name or enter a custom name.
Duplicate profile names include a number. For example, Run(2).
Select an option:
Select Use Default to create your custom profile starting from the system default settings.
Select a copy of an existing profile to create your custom profile starting from one of your saved profiles.
NOTE: If you are creating a custom multisport profile, you can select two or more profiles and include transitions. -
If necessary, select an option:
Select Yes to turn on the GPS during your activity.
Select No to turn off the GPS during your activity.
Select an option:
Select Edit Settings to customize specific profile settings.
Select Done to save and use the custom profile.
Parent Topic: Activity Profiles
