Going for a Run
The first fitness activity you record on your device can be a run, ride, or any outdoor activity. You may need to charge the device (Charging the Device) before starting the activity.
  1. Select Start symbol , and select an activity profile.
  2. Go outside, and wait while the device locates satellites.
  3. Select Start symbol to start the timer.
  4. Go for a run.
    Activity timer with run data
  5. After you complete your run, select Start symbol to stop the timer.
  6. Select an option:
    • Select Resume to restart the timer.
    • Select Save to save the run and reset the timer. You can select the run to view a summary.
      Run summary data
    • Select Discard > Yes to delete the run.
Copyright © Garmin. All rights reserved.GUID-45C11350-FBF5-4264-8316-A857189282E1 v4
