Marking Your Location
Before you can mark a location, you must enable the map screen for your activity profile and locate satellites.
A location is a point that you record and store in the device. If you want to remember landmarks or return to a certain spot, you can mark a location.
  1. Go to the place where you want to mark a location.
  2. Select Down arrow symbol to view the map.
  3. Hold Up arrow symbol.
  4. Select Save Location.
    The location appears on the map with the date and time.
Copyright © Garmin. All rights reserved.GUID-45C11350-FBF5-4264-8316-A857189282E1 v4
