Controlling a VIRB Action Camera
Before you can use the VIRB® remote function, you must enable the remote setting on your VIRB camera. See the VIRB Series Owner's Manual for more information.
  1. Turn on your VIRB camera.
  2. Pair the VIRB camera with your Forerunner® device (Pairing ANT‍+ Sensors).
  3. On the Forerunner device, select the VIRB accessory.
    When the VIRB accessory is paired, the VIRB screen is added to the data screens for the active profile.
  4. Select an option:
    • Select Timer Start/Stop to control the camera using the timer Start symbol.
      Video recording automatically starts and stops with the Forerunner device timer.
    • Select Manual to control the camera using the shortcut menu. From the VIRB widget, you can hold Start symbol to control the camera.
Copyright © Garmin. All rights reserved.GUID-45C11350-FBF5-4264-8316-A857189282E1 v4
