Calibrating Your Power Meter
Before you can calibrate your power meter, you must install it, pair it with your device, and ensure the power meter is actively transmitting data.
For calibration instructions specific to your power meter, see the manufacturer's instructions.
  1. Select Menu symbol > Sensors.
  2. Select your power meter.
  3. Select Calibrate.
    TIP: Keep your power meter active until the message appears.
  4. Follow the on-screen instructions.
August 2026
