Using ClimbPro
The ClimbPro feature helps you manage your effort for upcoming climbs. You can view details about the climbs, including when they occur, average gradient, and total ascent. The climb scores, based on length and gradient, are indicated by color.
  1. Enable the ClimbPro feature for the activity profile (Training Settings).
  2. Select Climb Detection.
  3. Select the climb categories to include, based on difficulty (Climb Categories).
  4. Select Mode.
  5. Select an option:
    • Select When Navigating to use ClimbPro only when you are following a course (Courses) or navigating to a destination (Navigating to a Location).
    • Select Always to use ClimbPro with all rides.
  6. Select Terrain Type, and select an option.
  7. Review the climbs in the climb explore widget (Using the Climb Explore Widget).
    TIP: Climbs also appear in the course details (Viewing Course Details).
  8. Go for a ride.
    At the start of a climb, the ClimbPro screen appears automatically.
    ClimbPro data
    1
    Distance remaining in the current climb
    2
    Average gradient remaining in the current climb
    3
    Current gradient
    4
    Ascent remaining in the current climb
After you save the ride, you can view the climb splits in your ride history.
  1. Scroll to the climb explore widget.
    TIP: You can add the climb explore widget to the widget loop (Customizing the Widget Loop).
  2. Select Menu symbol.
  3. Select an option:
    • Select Search Radius to enter the distance to search for climbs.
    • Select Min Difficulty to set the minimum climb category (Climb Categories).
    • Select Max Difficulty to set the maximum climb category (Climb Categories).
    • Select Terrain Type to indicate what type of terrain you will be riding on.
    • Select Sort by to sort the climbs by distance, ascent, length, or grade.
    • Select Sort Order to sort the climbs in ascending or descending order.
Climb Categories
Climb categories are determined by climb score, which is calculated using the grade multiplied by the length of the climb. A climb must have a length of at least 500 meters and an average grade of at least 3 percent to be considered a climb.
Category
Climb Score
Color
Hors Category (HC)
Greater than 80,000
Dark red
Category 1
Greater than 64,000
Red
Category 2
Greater than 32,000
Orange
Category 3
Greater than 16,000
Yellow
Category 4
Greater than 8,000
Green
Uncategorized
Greater than 1,500
Green
August 2026
