Customizing the Widget Loop
You can change the order of widgets in the widget loop, remove widgets, and add new widgets.
  1. Select Menu symbol > System > Widgets.
  2. Select an option:
    • Select Add Widgets to add a widget to the widget loop.
    • Select Rearrange the menu symbol to drag the widget up or down to change the location of the widget in the widget loop.
    • Swipe left on a widget, and select Delete symbol to remove the widget from the widget loop.
August 2026
