Viewing Widgets
Your device is preloaded with several widgets, and more are available when you pair your device with a phone or other compatible device.
  1. From the home screen or during a ride, swipe down from the top of the screen.
    Connection data
    The status widget appears. A flashing icon means the device is searching for a signal. A solid icon means the signal was found or the sensor is connected. You can select any icon to change the settings.
  2. Swipe left or right to view more widgets.
The next time you swipe down to view the widgets, the last widget you viewed appears.
August 2026
