Data Fields
NOTE: Not all data fields are available for all activity types. Some data fields require compatible accessories to display data. Some data fields appear in more than one category on the device. Some data fields are groups of related data, such as cadence or power.
TIP: You can also customize the data fields from the device settings in the Garmin Connect™ app.
Cadence Fields
Name
Description
Avg Cadence
Cycling. The average cadence for the current activity.
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Lap Cadence
Cycling. The average cadence for the current lap.
Cycling Dynamics
Name
Description
Avg L. Peak Pwr Phase
The average power phase peak angle for the left leg for the current activity.
Avg Left Pwr Phase
The average power phase angle for the left leg for the current activity.
Avg PCO
The average platform center offset for the current activity.
Avg Right Pwr Phase
The average power phase angle for the right leg for the current activity.
Avg R. Peak Pwr Phase
The average power phase peak angle for the right leg for the current activity.
Lap L. Peak Pwr Phase
The average power phase peak angle for the left leg for the current lap.
Lap Left Pwr Phase
The average power phase angle for the left leg for the current lap.
Lap PCO
The average platform center offset for the current lap.
Lap R. Peak Pwr Phase
The average power phase peak angle for the right leg for the current lap.
Lap Right Pwr Phase
The average power phase angle for the right leg for the current lap.
Lap Time Seated
The time spent seated while pedaling for the current lap.
Lap Time Standing
The time spent standing while pedaling for the current lap.
Left Peak Pwr Phase
The current power phase peak angle for the left leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Left Power Phase
The current power phase angle for the left leg. Power phase is the pedal stroke region where positive power is produced.
Platform Center Offset
The platform center offset. Platform center offset is the location on the pedal platform where force is applied.
Right Peak Pwr Phase
The current power phase peak angle for the right leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Right Power Phase
The current power phase angle for the right leg. Power phase is the pedal stroke region where positive power is produced.
Time Seated
The time spent seated while pedaling for the current activity.
Time Standing
The time spent standing while pedaling for the current activity.
Distance Fields
Name
Description
Distance
The distance traveled for the current track or activity.
Lap Distance
The distance traveled for the current lap.
Last Lap Distance
The distance traveled for the last completed lap.
Distance Ahead
The distance ahead or behind the Virtual Partner®.
Odometer
A running tally of distance traveled for all trips. This total does not clear when resetting the trip data.
eBike
Name
Description
Assist Mode
The current eBike assistance mode.
eBike Battery
The remaining battery power of an eBike.
Shifting Advice
The recommendation to shift up or down based on your current effort. Your eBike must be in manual shifting mode.
Travel Range
The estimated distance you can travel based on the current eBike settings and remaining battery power.
Smart Travel Range
The estimated remaining distance the eBike will provide assistance, taking into account the local terrain.
Elevation Fields
Name
Description
30s VAM
The 30-second moving average of the average ascent velocity.
30s Vertical Descent Speed
The 30-second moving average rate of descent.
Asc. to Next Course Pt.
The remaining ascent to the next point on the course.
Ascent Remaining
During a workout or course, the remaining ascent when you are using an elevation target.
Avg VAM
The average ascent velocity for the current activity.
Avg. Vertical Descent Speed
The average rate of descent.
Elevation
The altitude of your current location above or below sea level.
Grade
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 ft.) you climb you travel 60 m (200 ft.), the grade is 5%.
Lap Ascent
The vertical distance of ascent for the current lap.
Lap Descent
The vertical distance of descent for the current lap.
Lap VAM
The average ascent velocity for the current lap.
Lap Vertical Descent Speed
The rate of descent for the current lap.
Total Ascent
The total elevation distance ascended since the last reset.
Total Descent
The total elevation distance descended since the last reset.
VAM
The rate of descent over time.
Force
Name
Description
3s Force
The 3-second moving average of force applied to the pedal platforms, in Newtons.
10s Force
The 10-second moving average of force applied to the pedal platforms, in Newtons.
30s Force
The 30-second moving average of force applied to the pedal platforms, in Newtons.
Avg Force
The average force applied to the pedal platforms during the activity, in Newtons.
Force
The force applied to the pedal platforms, in Newtons.
Lap Force
The average force applied to the pedal platforms during the current lap, in Newtons.
Lap Norm. Force
The normalized force applied to the pedal platforms during the current lap, in Newtons.
Last Lap Force
The average force applied to the pedal platforms during the previous lap, in Newtons.
Last Lap Norm. Force
The normalized force applied to the pedal platforms during the previous lap, in Newtons.
Max. Force
The maximum force applied to the pedal platforms during the activity, in Newtons.
Max. Lap Force
The maximum force applied to the pedal platforms during the current lap, in Newtons.
Normalized Force
The normalized force applied to the pedal platforms, in Newtons.
Gears
Name
Description
Di2 Battery Level
The remaining battery power of a Di2 sensor.
Di2 Shift Mode
The current shift mode of a Di2 sensor.
Front Gear
The front bike gear from a gear position sensor.
Gear Battery
The battery status of a gear position sensor.
Gear Combo
The current gear combination from a gear position sensor.
Gears
The front and rear bike gears from a gear position sensor.
Gear Ratio
The number of teeth on the front and rear bike gears, as detected by a gear position sensor.
Rear Gear
The rear bike gear from a gear position sensor.
Graphical
Name
Description
Cadence Bars
A bar graph showing your current, average, and maximum cycling cadence values for the current activity.
Cadence Graph
A line graph showing your cycling cadence values for the current activity.
Compass
A visual representation of the direction in which the device is pointing.
Elevation Graph
A line graph showing your current elevation, total ascent, and total descent for the current activity.
Heart Rate Bars
A bar graph showing your current, average, and maximum heart rate values for the current activity.
Heart Rate Graph
A line graph showing your current, average, and maximum heart rate values for the current activity.
HR Zone Bar
A bar graph showing your current heart rate zone (1 to 5).
Map
A visual representation of the surrounding physical features and direction in which the device is traveling.
3s Power Bar
A bar graph showing your 3-second average power output value for the current activity.
3s Power Graph
A line graph showing your 3-second average power output value for the current activity.
Speed Bars
A bar graph showing your current, average, and maximum speed values for the current activity.
Speed Graph
A line graph showing your speed for the current activity.
Heart Rate Fields
Name
Description
%Heart Rate Reserve
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
%Max Heart Rate
The percentage of maximum heart rate.
Aerobic Training Effect
The impact of the current activity on your aerobic fitness level.
Anaerobic Training Effect
The impact of the current activity on your anaerobic fitness level.
Avg %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Avg Heart Rate
The average heart rate for the current activity.
Avg %Max Heart Rate
The average percentage of maximum heart rate for the current activity.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor or another device that has wrist-based heart rate.
Heart Rate Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Lap Heart Rate
The average heart rate for the current lap.
Lap %Max Heart Rate
The average percentage of maximum heart rate for the current lap.
Last Lap Heart Rate
The average heart rate for the last completed lap.
Load
The training load for the current activity. Training load is the amount of excess post-exercise oxygen consumption (EPOC), which indicates the strenuousness of your workout.
Respiration Rate
Your respiration rate in breaths per minute (brpm).
Time in Zone
The time elapsed in each heart rate or power zone.
Lights
Name
Description
Battery Status
The remaining battery power of a bike light accessory.
Beam Angle Status
The headlight beam mode.
Light Mode
The light network configuration mode.
Lights Connected
The number of connected lights.
MTB Performance
Name
Description
60s Flow
The 60-second moving average of the flow score.
60s Grit
The 60-second moving average of the grit score.
Flow
The measurement of how consistently you maintain speed and smoothness through turns in the current activity.
Grit
The measurement of difficulty for the current activity based on elevation, gradient, and rapid changes in direction.
Lap Flow
The overall flow score for the current lap.
Lap Grit
The overall grit score for the current lap.
Navigation Fields
Name
Description
Ascent Remaining
Course Pt. Distance
The remaining distance to the next point on the course.
Destination Location
The position of your final destination.
Dist. to Point
The remaining distance to the next point.
Distance to Destination
The remaining distance to the final destination. You must be navigating for this data to appear.
Distance to Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
ETA at Destination
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
Heading
The direction you are moving.
Next Waypoint
The next point on the route. You must be navigating for this data to appear.
Time to Destination
The estimated time remaining before you reach the destination. You must be navigating for this data to appear.
Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
Time to Point
The remaining time to the next point.
Other Fields
Name
Description
Battery Level
The remaining battery power.
Calories
The amount of total calories burned.
GPS Signal Strength
The strength of the GPS satellite signal.
Laps
The number of laps completed for the current activity.
Performance Condition
The performance condition score is a real-time assessment of your ability to perform.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
24-Hour Minimum Temperature
The minimum temperature recorded in the last 24 hours from a compatible temperature sensor.
24-Hour Maximum Temperature
The maximum temperature recorded in the last 24 hours from a compatible temperature sensor.
Power Fields
Name
Description
%FTP
The current power output as a percentage of functional threshold power.
3s Balance
The 3-second moving average of the left/right power balance.
3s Power
The 3-second moving average of power output.
3s Watts/kg
The 3-second moving average of power output in watts per kilogram.
10s Balance
The 10-second moving average of the left/right power balance.
10s Power
The 10-second moving average of power output.
10s Watts/kg
The 10-second moving average of power output in watts per kilogram.
30s Balance
The 30-second moving average of the left/right power balance.
30s Power
The 30-second moving average of power output.
30s Watts/kg
The 30-second moving average of power output in watts per kilogram.
Avg Balance
The average left/right power balance for the current activity.
Avg Power
The average power output for the current activity.
Avg Watts/kg
The average power output in watts per kilogram.
Balance
The current left/right power balance.
Intensity Factor
The Intensity Factor™ for the current activity.
Kilojoules
The accumulated work performed (power output) in kilojoules.
Lap Balance
The average left/right power balance for the current lap.
Lap NP
The average Normalized Power™ for the current lap.
Lap Power
The average power output for the current lap.
Last Lap NP
The average Normalized Power for the last completed lap.
Last Lap Power
The average power output for the last completed lap.
Lap Watts/kg
The average power output in watts per kilogram for the current lap.
Max. Lap Power
The top power output for the current lap.
Max. Power
The top power output for the current activity.
Normalized Power
The Normalized Power for the current activity.
Pedal Smoothness
The measurement of how evenly a rider is applying force to the pedals throughout each pedal stroke.
Power
Cycling. The current power output in watts.
Power Zone
The current range of power output (1 to 9) based on your FTP or custom settings.
Time in Zone
The time elapsed in each power zone.
Torque Effectiveness
The measurement of how efficiently a rider is pedaling.
TSS
The Training Stress Score™ for the current activity.
Watts/kg
The amount of power output in watts per kilogram.
Smart Trainer
Name
Description
Trainer Controls
During a workout, the resistance force applied by an indoor trainer.
Speed Fields
Name
Description
Avg Speed
The average speed for the current activity.
Lap Speed
The average speed for the current lap.
Last Lap Speed
The average speed for the last completed lap.
Max. Speed
The top speed for the current activity.
Speed
The current rate of travel.
Timer Fields
Name
Description
Avg Lap Time
The average lap time for the current activity.
Elapsed Time
The total time recorded. For example, if you start the activity timer and bike for 10 minutes, then stop the timer for 5 minutes, then start the timer and bike for 20 minutes, your elapsed time is 35 minutes.
Lap Time
The stopwatch time for the current lap.
Last Lap Time
The stopwatch time for the last completed lap.
Timer
The current time of the activity timer.
Time Ahead
The time ahead or behind the Virtual Partner.
Segment Time
The amount of time racing the segment during the current activity.
Workouts
Name
Description
Calories to Go
During a workout, the remaining calories when you are using a calorie target.
Distance to Go
During a workout or course, the remaining distance when you are using a distance target.
Duration
The time remaining for the current workout step.
Heart Rate to Go
During a workout, the amount you are above or below the heart rate target.
Primary Target
During a workout, the target for the primary workout step.
Reps to Go
During a workout, the remaining repetitions.
Secondary Target
During a workout, the target for a secondary workout step.
Step Distance
During a workout, the distance for the current step.
Step Time
The time elapsed for the current workout step.
Time to Go
During a workout or course, the remaining time when you are using a time target.
Workout Comparison
A graph comparing your current effort to the workout target.
Workout Step
During a workout, the current step out of the total number of steps.
August 2026
