Charging the Device
NOTICE
To prevent corrosion, thoroughly dry the USB port, the weather cap, and the surrounding area before charging or connecting to a computer.
NOTE: The device will not charge when outside the approved temperature range (Edge Specifications).
  1. Pull up the weather cap 1 from the USB port 2.
    Bottom view of the device with callouts
  2. Plug the cable into the charging port on the device.
  3. Plug the other end of the cable into a USB charging port.
    When you connect the device to a power source, the device turns on.
  4. Charge the device completely.
After you charge the device, close the weather cap.
About the Battery
WARNING
This device contains a lithium-ion battery. See the Important Safety and Product Information guide in the product box for product warnings and other important information.
August 2026
