Installing the Cadence Sensor
NOTE: If you do not have this sensor, you can skip this task.
TIP: Garmin® recommends you secure your bike on a stand while installing the sensor.
  1. Select the band size that fits your crank arm 1 securely.
    The band you select should be the smallest one that stretches across the crank arm.
  2. On the non-drive side, place and hold the flat side of the cadence sensor on the inside of the crank arm.
  3. Pull the bands 2 around the crank arm, and attach them to the hooks 3 on the sensor.
    Cadence sensor with callouts
  4. Rotate the crank arm to check for clearance.
    The sensor and bands should not contact any part of your bike or shoe.
    NOTE: The LED flashes green for five seconds to indicate activity after two revolutions.
  5. Take a 15 minute test ride and inspect the sensor and bands to ensure there is no evidence of damage.
August 2026
