Profiles
The Edge® bike computer has several ways for you to customize the device, including profiles. Profiles are a collection of settings that optimize your device based on how you are using it. For example, you can create different settings and views for training and mountain biking.
When you are using a profile and you change settings such as data fields or units of measurement, the changes are saved automatically as part of the profile.
Activity Profiles
You can create activity profiles for each type of biking. For example, you can create a separate activity profile for training, for racing, and for mountain biking. The activity profile includes customized data pages, activity totals, alerts, training zones (such as heart rate and speed), training settings (such as Auto Pause® and Auto Lap® features), and navigation settings.
TIP: When you sync, activity profiles are saved in your Garmin Connect™ account and can be sent to your device at any time.
User Profile
You can update your sex, age, weight, and height settings. The device uses this information to calculate accurate ride data.
Setting Up Your User Profile
  1. Select Menu symbol > My Stats > User Profile.
  2. Select an option.
Gender Settings
When you first set up the device, you must choose a sex. Most fitness and training algorithms are binary. For the most accurate results, Garmin® recommends selecting your sex assigned at birth. After the initial setup, you can customize the profile settings in your Garmin Connect account.
Profile & Privacy
Enables you to customize the data on your public profile.
User Settings
Sets your sex. If you select Not Specified, the algorithms that require a binary input will use the sex you specified when you first set up the device.
August 2026
