Updating Your Activity Profile
You can customize your activity profiles. You can customize your settings and data fields for a particular activity or trip (Training Settings).
TIP: You can also customize the activity profiles from the device settings in the Garmin Connect™ app.
  1. Select Menu symbol > Activity Profiles.
  2. Select an option:
    • Select a profile.
    • Select Create New to create a new profile by copying an existing profile or using a template.
  3. If necessary, select Menu symbol to edit the name, color, and default ride type for the profile.
    TIP: After a ride that is not typical, you can manually update the ride type. Accurate ride type data is important for creating bike friendly courses.
August 2026
