Installing the Out-Front Mount
NOTE: If you do not have this mount, you can skip this task.
  1. Select a secure location to mount the Edge® bike computer where it does not interfere with the safe operation of your bike.
  2. Use the hex key to remove the screw 1 from the handlebar connector 2.
    Outfront mount with callouts
  3. Place the rubber pad around the handlebar:
    • If the handlebar diameter is 25.4 mm or 26 mm, use the thicker pad.
    • If the handlebar diameter is 31.8 mm, use the thinner pad.
    • If the handlebar diameter is 35 mm, do not use a rubber pad.
  4. Place the handlebar connector around the rubber pad.
  5. Replace and tighten the screw.
    NOTE: Garmin® recommends tightening the screw so the mount is secure, with a maximum torque specification of 7 lbf-in. (0.8 N-m). You should check the tightness of the screw periodically.
  6. Align the tabs on the back of the Edge bike computer with the bike mount notches 3.
    Outfront mount with a callout
  7. Press down slightly and turn the Edge bike computer clockwise until it locks into place.
Releasing the Edge
  1. Turn the Edge clockwise to unlock the device.
  2. Lift the Edge off the mount.
August 2026
