Setting Navigation Alerts
You can set alerts to help you navigate to your destination.
Hold
- Select .
Select an option:
To set an alert for a specified distance from your final destination, select Final Distance.
To set an alert for the estimated time remaining until you reach your final destination, select Final ETE.
To set an alert when you stray from the course, select Off Course.
To enable turn-by-turn navigation prompts, select Turn Prompts.
- If necessary, select Status to turn on the alert.
If necessary, enter a distance or time value, and select
Parent Topic: Navigation Settings
