Setting Your Power Zones
The values for the zones are default values based on gender, weight, and average ability, and may not match your personal abilities. If you know your functional threshold power (FTP) value, you can enter it and allow the software to calculate your power zones automatically. You can manually adjust your zones on the device or using your Garmin Connect™ account.
  1. Hold Menu symbol.
  2. Select User Profile > Power Zones > Based On.
  3. Select an option:
    • Select Watts to view and edit the zones in watts.
    • Select %FTP to view and edit the zones as a percentage of your functional threshold power.
  4. Select FTP, and enter your FTP value.
  5. Select a zone, and enter a value for each zone.
  6. If necessary, select Minimum, and enter a minimum power value.
Copyright © Garmin. All rights reserved.GUID-42E081B7-11AC-4739-AA63-CA7BF685811B v10
