Pulse Oximeter
The Forerunner® device has a wrist-based pulse oximeter to gauge the peripheral saturation of oxygen in your blood. Knowing your oxygen saturation can help you determine how your body is acclimating to high altitudes for alpine sport and expedition.
You can manually begin a pulse oximeter reading by viewing the pulse oximeter widget (Getting Pulse Oximeter Readings). You can also turn on all-day readings (Turning On All-Day Acclimation Mode). When you remain motionless, your device analyzes your oxygen saturation and your elevation. The elevation profile helps indicate how your pulse oximeter readings are changing, relative to your to elevation.
On the device, your pulse oximeter reading appears as an oxygen saturation percentage and color on the graph. On your Garmin Connect™ account, you can view additional details about your pulse oximeter readings, including trends over multiple days.
For more information about pulse oximeter accuracy, go to garmin.com/ataccuracy.
The elevation scale. |
A graph of your average oxygen saturation readings for the last 24 hours. |
Your most recent oxygen saturation reading. |
The oxygen saturation percentage scale. |
A graph of your elevation readings for the last 24 hours. |
- Getting Pulse Oximeter Readings
- Turning On Pulse Oximeter Sleep Tracking
- Turning On All-Day Acclimation Mode
- Tips for Erratic Pulse Oximeter Data
