Playing Audio Prompts During Your Activity
You can enable your watch to play motivational status announcements during a run or other activity. Audio prompts play on your connected headphones using Bluetooth® technology, if available. Otherwise, audio prompts play on your phone paired through the Garmin Connect™ app. During an audio prompt, the watch or phone mutes the primary audio to play the announcement.
NOTE: This feature is not available for all activities.
  1. From the watch face, hold Menu symbol.
  2. Select Settings > Audio Prompts.
  3. Select an option:
    • To hear a prompt for each lap, select Lap Alert.
      NOTE: The Lap Alert audio prompt is enabled by default.
    • To customize prompts with your pace and speed data, select Pace/Speed Alert.
    • To customize prompts with your heart rate data, select Heart Rate Alert.
    • To customize prompts with power data, select Power Alert.
    • To hear prompts when you start and stop the timer, including the Auto Pause® feature, select Timer Events.
    • To hear prompts for each workout step, select Workout Alerts.
    • To hear activity alerts play as an audio prompt, select Activity Alerts.
    • To hear a sound play right before an audio alert or prompt, select Audio Tones.
    • To change the language or the dialect of the voice prompts, select Dialect.
Copyright © Garmin. All rights reserved.GUID-42E081B7-11AC-4739-AA63-CA7BF685811B v10
