Turning Off the Wrist-based Heart Rate Monitor
The default value for the Wrist Heart Rate setting is Auto. The device automatically uses the wrist-based heart rate monitor unless you pair an ANT+® heart rate monitor to the device.
NOTE:
Disabling the wrist-based heart rate monitor also disables the wrist-based pulse oximeter sensor. You can perform a manual reading from the pulse oximeter widget.
From the heart rate widget, hold
- Select .
Parent Topic: Wrist-based Heart Rate
